RCU Forums - View Single Post - CA hinge question
Old 03-13-2005 | 08:46 PM
rob6894
Default RE: CA hinge question
Hi Guys I have a kangke cap232 1/4 scale that I just baught used. This plane has ca hinges in it. the guy I baought it from said he never had problems with the ca hinges and did not think I would have any problems. My question is should I pin the ca hinges. If so I was thinking of using the above methode but using t-pins then cutting them qnd pushing them in also should I use ca on the pin. My only concern is that I don't in anyway wont to weakin the hinge where it is bonded in the wing by pushing the pins in.
Rob
