RE: OFFICAL TIPS AND TRICKS THREAD
If your recoil freewheels then put a hole in the top and bottom of the recoil case then shoot some carb cleen doun in there every time you are done for the day. That will cleen all the excess pil off the one way bearing. unless you have a mach .15 engine where the one way bearing is in the crank case. or a similar engine.
