RE: Ailerons on a Kadet Senior?
adverse yaw
Nothing dastardly happens. It is an annoying tendency to want to continue straight or veer to the right slightly during a left aileron bank. Usually more bank than necessary is required to turn and usually left ruder will help correct the tendency. If you watch the ARF’s fly the adverse yaw tendency can be readily seen. The airplane simply does not track well.
Bill
