RCU Forums - View Single Post - Clippard and Spring Airs
Old 03-15-2005 | 03:52 PM
FalconWings's Avatar
FalconWings
My Feedback: (57)
Default Clippard and Spring Airs
Hi guys,
I have a clippard 3-way, I assume normally closed valve for my Spring Airs. Problem is,when I presurize the air tank, there is an open port that leaks air gradually, and eventually loses all pressure (takes about 2 minutes). The port bleeds air in off and on position, however if I block the port the bleeding will stop, but it won't extend the landing gear.
Has my valve gone bad? Can I use a normal Robart valve and "jumper" the unused port?
David
