RCU Forums - View Single Post - durable remote glow igniter for YS
Old 09-20-2002 | 08:03 PM
Ladyflyer's Avatar
Ladyflyer
Default durable remote glow igniter for YS
Some people use a brass wheel collar with a wire soldered on , If you drill and tap a second setscrew hole it should be at right angle to the other hole rather than 180 degrees from it. It may also help to secure the wire with an insulated clip near the plug to support the connection rather than rely on the connector to do all the holding.
