RCU Forums - View Single Post - ECHO 44 CONVERSION
Old 03-16-2005 | 12:41 AM
airbr
Default RE: ECHO 44 CONVERSION
You should not have any trouble with that installation. You may find that as you are flying and more air gets ram in the carb yoy may have to richin it a bit on the high like was said earlier. If possible you may have to relocate the regulator diaphram hole. It should be powerfull!. What is the saw model number by chance?.
Good luck.
