RCU Forums - View Single Post - Sukhoi Elevator Problems
Old 03-16-2005 | 01:21 AM
14th_Reaper's Avatar
14th_Reaper
My Feedback: (-1)
Default Sukhoi Elevator Problems
Hi Mike.
I have started work on my Sukhoi again, and the more I get into it the more disappointed I am getting. Went to hook up the elevator halves tonight. Check the length of my prolinks, check the position of the servo arms everything seems ok. Level the counterbalances with the front part of the stabilizer and check the incedence (hope this is the right term) between the two halves and guess what? It is off by 1/2". Strange thing is, I had another set of elevator halves from another Sukhoi. Slide them on, same thing-- 1/2" difference when the elevator halves match at the counterbalances. What should I do? How can you correct a problem like this? I have pictures of when I matched the back of the elevators showing the difference in the front of the counterbalances. The airframe you see is the replacement that was sent from Horizon. The wings (not shown) and stabilizer are from the original arf. When they shipped the fuse, all that was in it was the fuse, rudder and canopy/hatch assembly, which was all I was expecting and I did receive fast and curteous service.
P.S.
I know the molded swivel clevis isn't set to the right height in the pictures, but even when adjusted properly (5/8") the same problem exists.
ID:	244586   Click image for larger version
ID:	244587   Click image for larger version
