RE: ECHO 44 CONVERSION
There is alot in those pics I missed the first time. It appears that there was weight reduction on the carb spacer as well. Did the engine side also get some relief machining? I like detail, you spent some time on this.
The flange holding the sensor pick-up appears to have two studs protruding forward. Did you install the studs and flange or where the part of the case?
