RE: Smoke in the Turbine duct P-80
Hi Matt,
No changes, just the weather, was the warmer day since a long time (30 deg Celsius) other than that is the same, it was not just a little smoke, after the two flights I started the engine one more time just to check if this smoke was there again, it was, the idle pump voltage was 0.6 v and at shut down was 0.9v.
Regards,
RM
