RCU Forums - View Single Post - Sukhoi Elevator Problems
Old 03-16-2005 | 02:33 PM
Geistware
My Feedback: (16)
Default RE: Sukhoi Elevator Problems
I have the same problem but figured that once I get it dialed in, there will not be much effect. Is this wrong/ If I line the front up there is at least 1/2 inch difference between the trailing edges of the control surfaces. If I align the trailing edges of the control, then one side is flush, the other side is up about 1/4 inch. Now that is already attached, how do you heat and twist?
