RE: Great Planes Little Toni firewall issue
Most if not all firewalls need to be reinforced. I do it religiously on all my arfs. Also a plane has retracts, then the mounting blocks. Just get the plane. Check the gear mounting on the Toni. I wouldn't worry about it. I mix a combo of epoxy and GP milled fiberglass. Saves the use of cloth and holds up good. Sand the corners a bit and slap it on their -inside and out.
