I have finally fixed my thrust problem on my reach whirlwind although im still not getting enough power. While I was building it I put some wires in the wrong way and the battery started to blow up and smoke along with the esc smoking, also the motor turned slowly, i think my power problem is related to this, which part do you think is wasted, engine/gearbox, esc, battery
post back any ideas on how to fix this or what i need to buy. note the battery esc and motor all came as a pack so its not to do with wrong setup, alsoit was the wire going from the esc to the battery that i put in the wrong way!!! please post your ideas on what i should do next here thnx!
Maidin
