Electric Training If you are new to electric learn more about them here or ask questions.
QUERY!
Old 03-17-2005 | 02:34 AM
Default QUERY!
I have finally fixed my thrust problem on my reach whirlwind although im still not getting enough power. While I was building it I put some wires in the wrong way and the battery started to blow up and smoke along with the esc smoking, also the motor turned slowly, i think my power problem is related to this, which part do you think is wasted, engine/gearbox, esc, battery
post back any ideas on how to fix this or what i need to buy. note the battery esc and motor all came as a pack so its not to do with wrong setup, alsoit was the wire going from the esc to the battery that i put in the wrong way!!! please post your ideas on what i should do next here thnx!
Maidin
Old 03-17-2005 | 08:34 AM
Matt Kirsch's Avatar
My Feedback: (21)
Default RE: QUERY!
I've been down this road before myself... Happens to everyone at some point. Anything that smoked will need to be replaced.
Old 03-17-2005 | 12:01 PM
Default RE: QUERY!
ok so i will replace the esc and battery, i dont think the motor smoked but i guess i could alwasy get that afterwards if it still aint goin good! thnx heaps matt
Old 03-17-2005 | 06:30 PM
Default RE: QUERY!
Seems like problem aviodance would be a good thing Matt. So is there anyway to check polarity or what ever before smokin something?
Gene
Old 03-19-2005 | 07:37 AM
AgCat1982's Avatar
Default RE: QUERY!
Your wires should be color coded on the ESC with RED as the "+" and Black as the "-" terminal. If there are different colors, look on the circuit board and it should show "+" and "-". I don't know any other way for you to do it, if it is not in your instruction sheet.
Good luck!
