RCU Forums - View Single Post - DA-50R question?
Old 03-17-2005 | 03:03 AM
obolel
Default RE: DA-50R question?
ORIGINAL: SPACE SCOOTER
Hello all,
I've been losing sleep trying to figure out which 50cc to go with. This will be my first go around with gasoline engines and it looks like the DA 50 is going to be my choice. I have a few questions if somebody would like to tackle them. 1.) Is the ignition battery powered and if so what size battery are you going with? 2.) How long is the flight time on a single charge? 3.) How long do you break the engine in before you put it in the air? 4.) Do you run a 2 or 3 blade prop for noise reduction? 5.) Does a Pitts style muffler give more power and better noise reduction?. Thanks to anyone who can help me out with these questions.........Scooter
1. I use a 110 MaH NiMh, light, gives at least 5 - 6 flights,
2. 5 - 6 12-minute flights per ignition charge
3. Just adjust a little rich and take off...
4. I don't need noise reduction, I use 23x8 Mejzlik. 3 blade will help to reduce noise.
5. Can't compare, because I use only Pitts.
