RE: CG setup on Harrier 90
If the fuel tank is in the stock location set it with the tank EMPTY.
If the tank is right over the cg point it does not matter, empty or full.
If for some reason you put the tank behind the cg point you need to set it with the tank FULL.
Ed M.
