RCU Forums - View Single Post - Need airfoil advice
Old 03-19-2005 | 07:42 AM
N1EDM
Default RE: Need airfoil advice
Hi Arthur,
Thanks for the info. I'll look up that note on the Delta Fighter thread (I presume that it's there). Thanks for the heads-up about the fuel line... I'll check it and make sure that I don't have any problems.
Sorry for diverting this thread, folks. Hope that you didn't mind.
Snitch, what type of flying are you going to do with the plane? If it's for general sport flying, then washout would be a good idea... If you're building an 'approximate scale' Mosquito, perhaps 1/4" to 3/8" would be nice. Also, that's a pretty severe taper, so could you widen the tip ribs to make them wider than 5" and still keep with the 'looks' of the mosquito? Your wing is going to do a lot of flying in the center, but not have a whole lot of lift at the tips. I'd vote for the washout.
Bob
