Servo setup meter
Folks,
I know servo setup meters have been discussed, but after doing a search I couldn't find what I had read before. Does anyone recommend a meter of some sort that I could use on the bench to set up control linkages, control surfaces, and servos to identify binding or other bad things that may draw excessive battery power?
I am using a 6volt system with both digital and analog servos
Thanks.
Chris
