RCU Forums - View Single Post - are mini/micro accessories to small for this plane?
Old 03-19-2005 | 09:38 PM
84 OLDSTYLE
Default are mini/micro accessories to small for this plane?
I think I put this question in the wrong forum so I also put it in the (Electric general discussion) forum
This is my second electric, the first is a (Mountainmodels Miniflash) and I used mini/micro accessories (pushrods .032dia, control horns 1-16th ply, servos HiTec HS-55) it's about 14oz ready to fly!
The plane i'm building now is a(AirFlair Inc Sundancer 15) It's a High wing plane. will be around 2-2.25 lbs ready to fly, Wing span 42.5 in, Wing Area 313 sq in, Wing loading 15-16 oz/ sq ft. Will be used for Fully stalled, cross-controled (slip), spinning and snapping maneuvers, flat spins also knife edge flight.
My question is can I use mini/micro accessories (like DU-BRO park flyer accessories) on a plane this size or would they be to small? Should I move up to 2-56 pushrods/hardware and bigger servos? If I need to use the bigger size stuff what is best for a plane this size? Any and all advice would be a great help. If anyone has a setup that works good please let me know
Thank you for your time.
