RE: new Arf Boomerang 14lb thrust
Hey Gang,
I was lookig at ways the get the CG proper without adding ballast, being it lead or big batteries, weight is weight right? Anyway, here's ONE solution I stumbled upon.
Simply flip the DuBro 50oz tank over. This will allow it to move forward 3/4". Move the turbine forward the same amount. The tank lip does not get in the way of the leading edge bulkhead. Simple!
Of course, you can alwats cut the bulkhead away to clear the lip too!
Pictures tell all....
Comments please?
Dave Rigotti
