RCU Forums - View Single Post - differntial question
Old 03-21-2005 | 06:22 PM
jimbo1890's Avatar
jimbo1890
Default RE: differntial question
mate if you get the fg alloy adjustable diff upgrade what you do is put your diff internals into this housing and this gives you two set screws in the new diff housing that allows you to change the limited slip capability from zero to ninety percent by adjusting those screws via a thrust race inside the diff
if your diff internals are no good you can buy a complete adjustable diff you can just bolt on and adjust to your liking
hope this explains
