Getting flywheel off Ryobi 31cc
I just bought two of these things from Northern Tool for $49 each. I am having trouble getting the flywheel off so I can unbolt the flange. The shaft coming off the flywheel has a nut on it but from what I've read the flywheel should just come off by prying it. It is a ZR700R model and did not have a clutch on it. I think this is the short shaft version but not sure, it does have two rings on the piston. I've tapped in several places with a regular hammer and pried with two screw drivers but I don't want to try any harder because I can see it moving and don't want to bend the shaft. Any ideas?
Does anyone know of any P-38s flying with two of these?
Thanks!
