Getting flywheel off Ryobi 31cc
Old 03-21-2005 | 10:01 PM
Invertedflyby's Avatar
My Feedback: (15)
Default Getting flywheel off Ryobi 31cc
I just bought two of these things from Northern Tool for $49 each. I am having trouble getting the flywheel off so I can unbolt the flange. The shaft coming off the flywheel has a nut on it but from what I've read the flywheel should just come off by prying it. It is a ZR700R model and did not have a clutch on it. I think this is the short shaft version but not sure, it does have two rings on the piston. I've tapped in several places with a regular hammer and pried with two screw drivers but I don't want to try any harder because I can see it moving and don't want to bend the shaft. Any ideas?
Does anyone know of any P-38s flying with two of these?
Thanks!
Old 03-21-2005 | 10:21 PM
Default RE: Getting flywheel off Ryobi 31cc
I have not tried to take flywheel off the ryobi. I have takin them off a shindaiwa and a poulan with a wheel puller and it works great. If you don't have a wheel puller i'm not sure how you would get it off.
smallplanes
Old 03-21-2005 | 11:23 PM
Antique's Avatar
Thge flywheel are on a taper on the shaft..Take the nut off and use some heat from a propane torch around the center of the shaft..A tap from each side on the flywheel and it should fall off in your hand...
Old 03-22-2005 | 12:14 AM
My Feedback: (15)
Okay so I do need to take the center nut off? It is attached to a shaft that is about an inch long with a square in the middle for going onto the weedeater shaft. I tried turning it but it wouldn't budge so I thought it was attached to the flywheel and all the conversion instructions I can find don't mention anything about it.
Old 03-22-2005 | 12:19 AM
tkg
Yep remove the nut and apply a little heat just like RC said
Old 03-22-2005 | 09:23 AM
Hit that sob with a soft mallet and watch her fall in yer hand.
Old 03-22-2005 | 09:33 AM
My Feedback: (15)
Thks I will try it when I get home from work.
Old 03-22-2005 | 12:21 PM
The opening in the end of that shaft has a torx head bolt in it. Take that out and the collar will come off of the shaft. Then the flywheel should come tight off..
Ben in SC
Old 03-22-2005 | 09:18 PM
My Feedback: (15)
Got it!
I cranked hard on that nut to break it loose and after unscrewing it and a little tappy tap tap on the flywheel it came right off.
Thanks!
FWIW, there was no torx head in the shaft.
Old 03-22-2005 | 09:24 PM
tkg
The torx bolt is what usually holds on the clutch. No clutch no torx.
Old 03-23-2005 | 10:47 AM
When you get ready to install tighten up the prop hub or prop nut, try removing the the plug and stuffing some 1/8" or so cord into the cylinder head and let the piston press against it while tightening the ph or prop nut.
Also works for holding shaft on removal of that sometimes pesky center torq bolt!
Liquid Wrench or wd-40 with heat as mention above help also.
Old 03-23-2005 | 08:58 PM
ryobi-bob's Avatar
Hold the flywheel with a large pair of channel locks either around the magnet or around the counterbalance, turn the nut counter clockwise. it is a 5/16 - 24 thread.
after you have the nut off you can tap the flywheel and it will pop off, you may have to pry gently on one or two sides with a screwdriver while you tap.
Bob
Old 03-23-2005 | 09:01 PM
ryobi-bob's Avatar
the 700r is a short shaft with no clutch, has no torx bolt in the shaft
bob
Old 03-23-2005 | 10:09 PM
My Feedback: (15)
I stuck a large screwdriver in the fins to hold the flywheel.
Old 03-24-2005 | 07:15 PM
I stand corrected, I've only converted long shafts so far.
Hoping to make one fit in a H9 PT-19. We'll see if it fits this weekend, I'm just a little worried about the flywheel hitting the cowl.
Ben
Old 04-04-2005 | 09:20 PM
My Feedback: (15)
Did you get the engine to fit the PT-19? I did some looking and I guess H9 doesn't make that plane anymore, I found some old reviews for it. I wonder if the engine would fit in the H9 1.50 P-51 Mustang. They recommend that inline 200 Saito twin so it might be long enough. I was originally wanting to put mine in a Four Star 120 but would rather not build anything.
