RCU Forums - View Single Post - JMP Starfire
Thread: JMP Starfire
Old 03-21-2005 | 10:33 PM
patf's Avatar
patf
Default RE: JMP Starfire
are you planning on flying it as a df or turbine? i know yellow has provided thicker material for the formers throughout the kit. if you can still go with thicker material at the main formers, i would think you could do a removeable wing. i would be a bit hesitant if you plan on going turbine with the higher speed and wing loading.
