Texas Hurricane Setup
Your G-38 will fly it just fine at about 1/2 throttle. The Hurricane has a speed groove where it will do anything you ask without getting sensitive. You will find this speed probably before the first flight has ended, its that obvious, and its slower than you think it should be. Start with the recommended control throws and C.G. and work from there. If you have no experience with large planes you picked the perfect place to start, this plane is so easy to fly you're gonna be amazed.
