RCU Forums - View Single Post - Aircore 40 Elevator trim
Old 03-22-2005 | 06:13 PM
Tesla1856's Avatar
Tesla1856
Default RE: Aircore 40 Elevator trim
I haven't had that problem with mine. My elevator trim has always been none.
You might check your:
Check for "play" or binding in the linkages.
Be sure everything (like the battery) is secure in the cabin.
Balancing on Center of Gravity. With PC in-place and ready to fly except the fuel. Be sure it's not tail-heavy.
Elevator throw rate. It should only be 3/8 - 1/2 inches.
The wing should always be installed in the same place... centered and all the way back against the rear lip. At it's flight-ready weight of 8 lbs. , mine takes 16 rubberbands to keep the wing on and in-place during flight. It should not be moving at all.
http://www.vlsdynamics.com/rc/planes/us_aircore40.htm
