Aircore 40 Elevator trim
I have an Aircore 40 that I am learning to fly on. I am having trouble keeping the model in trim.. Every time I start the days flying, I need to re-trim the elevator. I mean large changes in trim.. Could it be a problem with different wing seating each time I re-install the wing? Fred 123[&:]
First off I would like to say I can't beleive the moderator hasn't tried to help you with this question. Secondly
I think you may have posted this question in the wrong area, ARF post room may be where you want to be.
OK , I dont know anything about US Aircore planes, but I have had this problem before with an electric plane. Check to see if the servo tray is moving around. If it is moving even just a little bit then this will be the answer to your problem.
If it isn't moving then make sure the elevator is not moving , then check the servo to see if it is stripped.
Good luck.
Good luck.
I haven't had that problem with mine. My elevator trim has always been none.
You might check your:
Check for "play" or binding in the linkages.
Be sure everything (like the battery) is secure in the cabin.
Balancing on Center of Gravity. With PC in-place and ready to fly except the fuel. Be sure it's not tail-heavy.
Elevator throw rate. It should only be 3/8 - 1/2 inches.
The wing should always be installed in the same place... centered and all the way back against the rear lip. At it's flight-ready weight of 8 lbs. , mine takes 16 rubberbands to keep the wing on and in-place during flight. It should not be moving at all.
http://www.vlsdynamics.com/rc/planes/us_aircore40.htm
My Feedback: (20)
A few years ago I had one of the Aircore Colts. I loved the plane but it was prone to elevator and rudder trim changes. I finally traced it to the long nyrods used in the kit. They will change length noticeably in hot/cold weather.
Matt
Matt
