RE: Wheel collar problems??????????
You might want to sharpen the Allen key on the belt sander or with the dremel cutoff wheel often. The slightest use seems to start rounding the corners of the Allen key. With a sharp key the striping tendency is much less. Also the LHS sells self-locking push on clips similar to E clips. Push on clips work well when the axle is too short for a collar.
Bill
