RE: Any prop adapters fit most motors?
You just need to know the diameter of the shaft...
don't forget that you usually can't just remove a gearbox and pop on the same size prop....
the gearbox allows the system to produce more torque....
depending on the motor, you usually need to go with a smaller prop if you use it as a direct drive.......
