Glue
Your best results is to not use any thinner, use 30 minute epoxy and, after putting it on the area, heat the area with your heat gun. You will see the epoxy suddenly get thin and wick into every nook and cranny. Don't get it so hot is bubbles, just hot enough to suddenly run.
