To check it, hook the meter in line and when you are charging the pack (1.0 amps) check to see if the current flowing to the pack is 1.0 amps. I did this check on my system and measured 200ma at 202.5 ma. This is close enough for me.
As far as how to calibrate it?
I would send it back to Hobby services with your readings.
Also make sure your meter is good.
Also check to see that the math is right.
If you charge at a particular current for the amount of time specified, make sure that the capacity reading matches the math.
ORIGINAL: Francis Fernand
Geistware,
I do not have any meter, but I can get one.
How do I know if the Elite is not calibrated ? or How do I calibrate the Elite ?
Thanks in advance,
