RE: replacing fuse in Tx?
You might check with your local Radio Shack, or a local TV repair shop. They should have one. You need to remember that the plugs on JR transmitters are different than all others. The center pin on the JR is negative and the barrel is positive. You need to get a special transmitter charge cord, or modify the one you have.
Rich
Wyoming Wind Festival Jan 1 to Dec 31
