RE: ESC Prob..
If the ESC isn't one of the new models, the programming card will be of no use. What setting are available on the older ESCs are programmed through the throttle on the transmitter, I believe.
The programming sequence should be described in the documentation, which does you absolutely no good if you lost/never had the documentation to begin with... I'll try to remember to look when I get home.
