Try Futba .com
The website is full of info ..........
http://www.futaba-rc.com/faq/faq-9c.html ...You my try one of the 3 position switches Like "G"as your throttle R-L kill and "H" as your idle down, I dont know this for a fact but it may work. And if that fails call the number on the website .....the 12 year old kid/radio guru should be able to help you set it up. Believe me I've called em myself....[sm=thumbup.gif] dont foreget to look in the radio forum ......Good luck and keep us posted on how it turns out...JW
ORIGINAL: rsmokin
SETTING UP A TWINSTAR WITH A FUTABA 9C AND HAVING TROUBLE. I HAVE CHANNEL 3 SET AS THE MASTER AND CHANNEL 6 AS THE SLAVE . I GET CONTROL OK WITH THE STICK AND THE THROTTLE TRIM ADJUSTS BOTH ENGINES. BUT I CAN'T KILL BOTH ENGINES WITH THROTTLE CUT, I CAN ONLY KILL THE MASTER.
ANY HELP WOULD BE APPRECIATED.
THANKS
