RE: 9C TWIN ENGINE SYNCING
A quote from ‘Getting The Most Out of Futaba’s 8-Channel Radio Control Systems’ book by Don Edberg. “Because the second engine is not plugged into CH3, the kill engine function will not work on it.”
I believe that you will need to use a switch to throw channel 6 to an offset that will shut the engine down. Maybe trim shutdown would work. Hope the information helps.
Bill
