RE: Starting problems
Just make sure that the engine is tuned properly and fuel is getting to it. And I hope you put after run oil in the engine when you stored it while the weather was bad. If you didn't then there could be fuel build up in the engine, which might keep it from starting. Hope it works out for you.
