Starting problems
Old 03-24-2005 | 02:21 PM
Gorbee's Avatar
Default Starting problems
Hey. I've got a Carson CS-4 car. It is fairly new and we broke the engine in with major frustration. Wouldn't start up, only started a few times and flooding the engine was the only solution to get it started. It did, then obviously it died. This has been going on ever since we tried getting it running (about a week, then it has snowed, rained and all other nonsense) Now the sun is out we are going back out with it tomorrow. Any tips on getting it started FIRST time? Or possibly second, not fussy Or possibly any ideas what could be wrong with it? Thanks
Old 03-24-2005 | 02:31 PM
Default RE: Starting problems
Just make sure that the engine is tuned properly and fuel is getting to it. And I hope you put after run oil in the engine when you stored it while the weather was bad. If you didn't then there could be fuel build up in the engine, which might keep it from starting. Hope it works out for you.
