info share
i found this out when i used to run nitro with my fail safe, it apears to work the same on my gas. i have a venom failsafe so it does the usualy apply to certain setting when radio kicks out. heres what i stumbled upon if you over brake you can get your engine to cut out as if a kill switch was in place. in doing this you can turn your standard failsafe into one that also can cut out the engine.
