RCU Forums - View Single Post - Oh Joy, Oh Rapture....
Old 03-24-2005 | 07:03 PM
agexpert
Default RE: Oh Joy, Oh Rapture....
Just remember CA is weak and flimsy compared to a 30 minute Epoxy. Use Epoxy wherever you need strength. Use CA where epoxy is impractical, too thick or just plain not needed.
Try to limit the amount of epoxy that you use in the tail. I don't mean use CA in the tail, I mean use only as much epoxy as necessary in order to minimize unneeded weight way back there. You may find yourself adding a lot of weight to the nose in balancing later on.
Beyond that; as long as you are confident in the bond you achieve, you can't go wrong.......except when you CA your forearm to the plans and your opposite palm to the workbench. UH....so I've heard.
Good Luck!!
