RCU Forums - View Single Post - Help on GT4 RTR
Thread: Help on GT4 RTR
Old 09-23-2002 | 11:43 PM
jpmotdyn
Default Help on GT4 RTR
I have a few questions i hope you guys could help me with....
1. When I apply throttle to my car it does not take off right away, maybe like a second later. Is it the clutch nut? How do i adjust it if it is?
2. When using after run oil, do i remove the glow plug, put some oil in there and turn the flywheel a few times? Or do i put the oils elsewhere?
3. When is exhaust smoke supposed to come out? All the time or only on 100% throttle? On mine it comes out pretty much most of the time except low throttle.
4. What is the best tire combo to use on the regular street? i am just messing around outside my house . Some have said slicks, hard in ft and soft in rear. Others have said treaded and others say use the Take Off ones.
5. When running a full tank of gas and checking the head after, the head seems to be very hot. I did the spit test and it evaporates 2-3 seconds later. I am running it rich...2 1/4 turns from closed???
6. Are aluminum hop ups necessary or is it mainly for race applications. Also what hop ups are recomended?
Thank you for all your help, Jason
