RE: H9 Extra 330L engine
I had a H9 Cap with ZDZ-80 single. It balanced best for sequence flying with a single rudder servo (Hitec 5375) on pull-pull cables. I also flew it for a hundred or so flights with 2 rudder servos in the tail. In either case, I just moved the batteries around to suit CG. The plane weighed 23.5 lbs.
