Only change is the spark coil is mounted behind the cylinder where the source coil was and 2 small rings around the hub near the crankcase.for the sensor and magnet...The carb has a new rotator block, 3/8 thick...The throttle servo connects directly to the carb, no bell crank...There is a small RCA jack in the case under the carb to connect the ignition circuit to the battery.....
