RE: Engine Info Needed
A belt can probably be ordered from a power transmision distributor who has V-belts ect. Your belt may even have the necessary number on it. If not, you should be able to measure it. The number you are looking for looks somthing like 60XL025. That number denotes a belt 6 inches long in circumference by .025 width and a tooth pitch of 5 teeth per inch. Good luck
