ORIGINAL: TManiaci
I ran my hellraiser it to the top of a tree today...
[snip]
So, if I don't get another Hellraiser, what is the best substitute without buying any new gear? Quasar, Tensor, Shocky?
Go for something sturdy.
I don't have either but I bet you'll tear up a Tensor or a Shocky. From what I've read the key to both of these planes is their super light weight. So I think they will suffer from too many layers of tape repairs.
Seriously, the HR is still a good plane and you've both shown it can take a beating and still be repairable. That should count for something.
Otherwise, I think you need another plane that has reinforced leading edges. The planes at 3dfoamy.com sport a "PRO" wing which laminates 3 layers of depron at the leading edge. Makes for a strong wing and gives it a unique airfoil. Like all profile planes, they are ugly.
You'll have to see what their power requirements are.
FWIW I've flown my HR *through* trees with only minor dents, I've pancaked it after pulling out of a loop too late, and I've tumbled it off a roof. All I've ever had to do was re-anchor one of the flying wires once. I credit this to my "armor"- I reinforced every glue joint, including the wing root joints, with strips of packing tape and I covered every exposed foam edge with 3/4" tape. So I have super strong non-tearing joints and non-tearing edges to the flat plate surfaces. Zero hangar rash as well. The plane easily absorbed the extra 1/10 ounce of weight.
I also mounted my battery pack to the plywood frame because I thought mounting it on the foam would tear the foam in a crash.
Happy Flying
Clark
