RE: HELP-Kill switch on Quadra 35
NGK BPMR6Y, Bosch WSR6F, anything with an "R" in the part number..
An old Q35 with points will not have an empty terminal on the coil, connect the kill switch to the wire that comes from under the flywheel..That wire goes from the points to the coil..Grounding the points kills the engine...
