To alter the incidence you are actually tipping the whole airfoil up at the trailing edge. Sanding just the trailing edge will not do it. If the saddle is a good fit to the wing then the whole saddle has to be sanded with more material being removed progressively towards the trailing edge.
I'm so fed up that I'm about to throw the front dowels away and glue in some more wing bolt blocks
I would do that anyway. Why risk all that you have in an airplane on a couple of wooden dowels. Use four screws. It is then easy to make adjustments to the wing after some flights.
Ed S
