RCU Forums - View Single Post - OS46 AX Stops when full throttle
Old 03-30-2005 | 09:57 AM
tIANci's Avatar
tIANci
Default RE: OS46 AX Stops when full throttle
I think you need to change the plug firstly. Also, if it holds when the glow is in is the engine peaking? Might it be on the rich side? When you throttle up, does the engine cut abrupty or gurgles a bit before it does stop? If it gurgles then the LOW END is too rich.
