RCU Forums - View Single Post - Rudder area above & below thrust line?
Old 03-09-2003 | 12:31 AM
StarskiPZ
Default Rudder enlargement
I did this to a semi-scale low wing monoplane (De-Haviland)...
and yes, there was quite a nose down pitch when you waggled that rudder.
As mentioned, the increased air pressure under the elevator would have this effect.... so what if I extended the fin rearwards of the elevator?
...Check if it will still fit in the boot !!
