RCU Forums - View Single Post - Propane
Thread: Propane
Old 09-25-2002 | 06:42 PM
KevinM's Avatar
KevinM
Default Propane + Butane
You're absolutely correct about the lower pressure of the propane/butane mix. SimJet engines will start on Powermax (and other blends) just like the other guys, but I prefer the cheaper and more readily available propane.
I believe the blended gas does in fact burn hotter, so you should come up to temp more quickly.
Will do on the regulator...
