RCU Forums - View Single Post - Right Thrust - Down Thrust....
Old 03-31-2005 | 01:20 AM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Right Thrust - Down Thrust....
bigdanusa,
What plane are you building? Check your instructions/plans first. A lot of kits/ARF's/plans will have the right trust built into the plane itsef, but usually have to add the down thrust. If you do use it, you can add it in by putting washers between the motor mount and the firewall.
Hope this helps.
