PULL PULL ON RUDDER
Swill I see that you are going to put PULL PULL on the Rudder.
I noticed some others also going to do this.
How are you going to do this as the plane is already covered and i dont see how you are going to be able to run the wires or cables or whatever you want to call them through the fuse and how are they going to exit the tail and also were are you going to mount the servo?
Any pics of how this is being done posted here would be GREAT!
Wouldnt it make more sense to put one strong torque wise servo in the tail with a short control wire than have a long pull pull system running through the fuse as less chance of flutter and problems?
Im kind of new so excuse these comments if they are all wrong im just looking for some input on this as I want to set this beautiful plane up the best that I can for a long lasting and enjoyable plane to fly.
Jeff
